When i go on the options on richard burns rally, i go to the controllers menu and try to go on the controller setup page, but when i choose it i see a slight flash of the menu but then it returns back to where i started, any ideas?
EDIT: Sorted it, this is what worked
Q3: I'm having problems with some games when I try and run them with the Gamers' Keyboard plugged in - what can I do?
A3: There are a couple of known games that have issues with the presence of the Gamers' Keyboard; known titles that have problems are the moment are Planetside, Star Wars: Battlefront and Thief: Deadly Shadows. Other titles may exist that have problems but they have not been reported yet.
There is a possible solution though - Click Start>Control Panel and open the System in there (you may have to click Performance and Maintenance before you can see the System icon if you're running Control Panel in Category View) and then click Hardware at the top of the window that comes up and then click Device Manager. Click the plus sign next to Human Interface Devices in the list of devices and you should see one or two (maybe more) entries called USB Human Interface Device. You need to disable one of them by right-clicking it and choosing Disable from the drop-down list of options.
Note: If you have only two such entries there in Device Manager then only one will be able to be disabled - the other will have the disable option greyed out in the drop-down list when you right click it. If however you have more than two such entries in Device Manager then you will need to ewnsure that you disable the correct one. This is done by double clicking on each one in turn and looking at what it says next to Location on the Properties page. The one that should be disabled will say USB Gaming Keyboard Pro next to
