Richcopy PURGE attribute ....
6 Feb 2003
Just started using microsofts RICHCOPY utility today, and it is nice to see a GUI instead of command for once. Athough there is a BIG different in the PURGE function between both the programs.
In robocopy, purge deletes files and folders on the destination location that are not found on the source location.
With Richcopy, purge deletes FILES ONLY on the destination location that are not found on the source drive. Can anyone help me with an option to select in Richcopy that will delete both files AND folders on the destination location that are not found in the source location ?
Thanks
