- 27 Dec 2005
- Bristol
I'm just trying to do a simple JS addition, but it's treating one of the vars as a string and I don't know to adjust this.
If packaging.value is 3 then it outputs 123. If I replace the + with a - or * then it works fine (ie outputs 9 and 36 respectively).
This is probably so simple that I doubt I need to explain any more, but it's doing my nut in. Cheers.
Code:
var baseprice = 12;
var packaging = document.getElementById("packaging");
totalprice = baseprice + packaging.value;
document.getElementById("totalprice").innerHTML = "£" + totalprice + ".00"
