Rift - 1060 for a year or 1070?
12 Jan 2004
London
Hi all
An almost impossible question to answer, but thought I'd see if anyone had any thoughts.
Obviously awful time to buy, but faced with the dilemma of needing a new card so can either get a 1060 6gb and look to replace it next year with something shiny or lock into a 1070 for two years. Obviously the price difference is about 150 quid.
As I would be mostly using it for VR on a Rift, anytime had any experience of using both? Does the 25% boost make a difference? Would be mostly playing dcs, skyrim etc.
I always buy the best card I can afford. You don't know what's coming in a year or what the prices will be like. I had the 1070 for the Rift and it a did a great job.
Saying that, at the moment the prices are a higher than normal. The mining craze seems to be over, prices should drop over the next few weeks.
You might take a look at the Members Market here, might be some good deals.
Suggest a 2nd hand 1070. They tend to go fairly cheap, and if you get one with a decent cooler, it should be still prime. Mine runs cool as you like.
What's the AMD equivalent to a 1070? I can't shake the feeling that vr would be better with 8GB
I've got two VR's one connected to a PC with a 1080 GTX, the other one is a 1060 6GB, admittedly the most stressful game we've played is Sunshine Arizona which I guess isn't that stressful. However, the playing experience is exactly the same on both...
The MM's is the place to look, a couple of 1070's for sale at the moment...
Agreed, if you can hold out for a 1070, the prices for new should be down very quick as a the mining profitability has now gone, so expect a flood of used cards!
