Rift 3rd/4th Sensor Layout Question
3 May 2011
Leicester
Good Evening Gents, I've spent the best part of this weekend running USB 3.0 Active cables through wall cavities but to get the very best VR experience for my Rift I bought a 3rd Sensor and have toyed with the thought of a 4th.
My question is however the location of these 3rd/4th sensors cannot be run through walls and instead will require a temporary setup. Is there anything like a telescopic pole that can be floor mounted and not too large that can use the Rift sensors thread? I'm just going to have to live with trailing cables for these sensors unless I go into skirting (which I'm not really wanting to do).
Something like a photography lighting stand with 1/4" threaded mount should work. Were you to search in the rainforest for a Phot-R Professional photography light stand I feel confident you'd find something suitable.
