Rift incoming. Help with new cinema room setup please.
16 Jun 2011
Have ordered a Rift from the Rain forest and it should be here by the end of the week. My room is used primarily as a cinema/gaming room. I can push my chair back giving ma a almost 3 meter square to play in. Will this be ok ?
Also I was thinking about mounting the two sensors on the side of my projector screen housing. At a later date adding a third on top of my projector, Would this be ok ? To high maybe ??
Last of all I have four glass cabinets in the room. One on the right quite far back but the one on my left is very much in the way. Will this be a problem ??
Please see pictures for more info.
Thanks for the help.
Pictures removed, Photobucket sucks.
That's loads of space, I game in about 1.3x2m, which is a bit restrictive but does the job. I used these adhesive camera mounts to stick my two sensors on the wall near the corners, but not too high, which has worked well.
I have 2x2m (maybe 2.5 if I start shifting furniture). 3 square meters is loads. As for glass cabinets, I used the ones in my room to my advantage, and used car GPS windscreen mounts to suction cup my sensors onto them - easy way to "wall mount" my sensors :)
