Rift S no spare DP
7 Jul 2008
Newcastle upon Tyne
I understand the Rift S uses a display port
however my rig is setup for triple monitors.
is there any other option so that i can use the Rift without having to unplug the monitors
Can your graphics card support 4 monitors? Got a spare HDMI port? If so, can one of your monitors use HDMI instead?
It does, the hdmi is currently being used by a 4th monitor but it would a lot less hassle to unplug that
So have the triplles on 2 DP and one Hdmi
good idea
If theTriples are 144 hz the HDMI might support only 60hz. Iv got a 1080 Zotac amp with loads of connections. One reason iv not upgraded to 2080ti
