Before I bought a Rift I ran the Oculus Compatibility Checker and it had no problems with my USB, I was expecting problems because I have a Gigabyte GA-Z77-D3H with an Etron controller, but it said everything was fine so I went ahead and bought it. I set it up without any problems, it had no complaints about the headset and one sensor being USB 3 and the second sensor USB 2, I then used it without problems for around 2 weeks.
Over the weekend I decided to upgrade to Windows 10 (made a backup image of my SSD first), the upgrade from Windows 7 to 10 went smoothly, the Rift continued to work perfectly but the computer was running slower, I was already overdue a clean install so decided to format and install a fresh version of Windows 10, again, everything went smoothly, until I installed Oculus home, the beginning of the setup was fine, it found the headset and both the sensors and didn't have any problems setting up the sensors and guardian, when it got to the "continue in your headset" part is where the problems started, the headset wouldn't turn on, the amber light was on and the software knew it was there but the display wouldn't turn on.
I made sure I'd installed all the drivers and everything seemed fine, ran the Oculus Compatibility Checker again and now it said my USB controller wasn't compatible! Not wanting to mess around I restored my Windows 7 backup image and everything was fine again.
Today I decided I'd give it another go, but this time disable the Etron controller in device manager, that worked as far as the headset now turns on, but I get warnings about one of the sensors not tracking properly, I've tried every combination of USB ports with the same results, I ignored it and carried on with the setup but the display keeps freezing for a second or two, making it almost impossible to use.
Now I could go back to Windows 7 again and leave it at that, but the reason I went to 10 in the first place is it's only a matter of time before all/most new releases won't support 7. I'm at that point where the performance increase isn't great enough to justify the cost of a new motherboard/processor/RAM, so a new motherboard with compatible USB 3 isn't happening, leaving me with one last solution, a USB 3 PCI-E card..
TL: DR, OcUK don't seem to sell the recommended Inateck card, does the StarTech 4 Port USB 3.0 PCI-E card (PEXUSB3S42) work with the Rift? I would really like to have it working properly by Wednesday, my son is coming to play on it and I'd rather not have to go through the whole restore Windows 7, format, install Windows 10, try again!
edit coz I've just read it and understand your ?
