Rift Wall mounting
29 Nov 2008
Scotland
Was looking for some advice on wall mouting brackets for the rift sensors, I am currently on 2 sensors and about to purchase a 3rd one, but ideally would like all 3 sensors up on the wall.
I used security camera mounts. Let me see if I can get the exact model for you.
Yeah, I if you search for Shappy 3 pack. They come in black or white.
Some people have used these mall mounts
https://www.amazon.co.uk/Shappy-Sec...863845&sr=8-1&keywords=rift+sensor+wall+mount
In the review part there some pictures of them being used with rift sensors..
I went the easiest (and cheapest) route. Made out of soft wood from DIY store that I had in the shed. All I used was a Cordless drill,Jigsaw, Picture Hanging Strip and White paint
It looks something like this
The mounts pictured above are exactly what I've used to (ceiling) mount my Rift sensors. I didn't even screw them into the ceiling, I just ran a bead of No More Nails around the mount and pressed them into place and wiped clean. I figured that should I ever wish to remove them, a quick knock with a hammer will move it and a bit of paint damage is easier to repair than 3 holes. Either way, they've been solid for about a year and haven't budged at all.
I picked up some adhesive swivel camera mounts off of amazon and they've been perfect for me. Had em up for over a year and still solid.
