Rig cleaning
13 Jan 2010
The 'Shire'
How often do you clean your system and what with....?
Mine is now 6 months old and will be given a good clean tonight with air spray for those hard to reach places and it coincides with some new parts also :D
I clean my rig about every second week as i have a compressor
....and buying new parts, dont get me started :eek: :D
New paint brushes (1" + 3"), air can and a vacuum cleaner hose with the brush attachment..
Once a month I spray it out with an air duster, run the dust filters under a hot tap, wipe down the exterior with a slightly damp cloth and clean the side window.
