Rig Upgrade £700
12 Jul 2011
I'm looking to upgrade my rig so i can play star citizen at very minimum settings any ideas on what would be best for my buck upgrade wise? Already have a Case, OS, and wouldn't mind keeping the PSU. edit : seen other thread asking for case details to make sure parts fit etc, so at the moment it's a oldddd antec 900, The CPU cooler is one of the waterpipe ones which have tubes coming off which connect to the back/top of the case so i'd also like to keep that if possible.
Operating System
Windows 8.1 Pro 64-bit
CPU
AMD A8-3850 17 °C
Llano 32nm Technology
RAM
8.00GB DDR3 @ 666MHz (9-9-9-24)
Motherboard
ASUSTeK Computer INC. F1A75-V PRO (FM1 ) 32 °C
Graphics
S240HL (1920x1080@60Hz)
2048MB ATI AMD Radeon R9 200 Series (ASUStek Computer Inc) 28 °C
Storage
931GB Seagate ST31000528AS (SATA) 26 °C
Audio
AMD High Definition Audio Device
Thanks
Hi,
Find out which PSU it is.
The video card is not specified (only that it's something in the R9 200 series). Use GPU-Z if needed.
The CPU cooler will need the mounting system for any new motherboard socket. So name would be useful even if chances are it will be okay.
GPU = Radeon R9 270, i'll purchase another psu add another £80 to the budget and i'll go for the stock cooler that comes with the cpu until i can afford better
thanks guys
Here is what i have so far but there is room in your budget for further upgrades . Will you crossfire in the future ?
Also there is skylake cpu the latest release from intel but im not sure the cost is worth the performance.
YOUR BASKET
1 x Gigabyte Z97X-SLI - Devils Canyon Core i5 4690K Bundle **£12 Saving** £263.98
1 x XFX Radeon R9 390 "DD Black Edition" 8192MB GDDR5 PCI-Express Graphics Card (R9-390P-8DB6) £259.99
1 x Samsung 250GB 850 EVO SSD 2.5" SATA 6Gbps 32 Layer 3D V-NAND Solid State Drive (MZ-75E250B/EU) £85.99
1 x Kingston HyperX Savage Red 8GB (2x4GB) DDR3 PC3-19200C11 2400MHz Dual Channel Kit (HX324C11SRK2/8) £38.99
Total : £648.95 (includes shipping : Ex.VAT).
