Hi All,
With the release of the new Witcher, I've been rudly reminded that my PC is definately overdue for an upgrade! I was hoping that somebody could give me some suggestions, as unfortunately, I'm lacking time to do proper research that would be needed to pull all this together by myself.
Below are my specs:
Case - CM Stryker Full Gaming Case
GPU - MSI Radeon 280x 3GB (Perhaps needs upgrade)
CPU - i5 3470 3.5ghz (needs upgrade)
RAM - 8GB (needs upgrade?)
Monitors - 24" Acer Predator 144hz / Hannspree 20"~ (currently unused as I've only got 1 DVI slot on the GPU)
PSU - Antec VP550p 550w (needs upgrade)
Motherboard - Will need a new one if I go with CPU that requires 2011 socket
HDD - WD Caviar Green 3TB 64MB Cache
SSD - None (considering buying one and installing OS & used applications on this)
I currently have a fan cooling on CPU but would you consider switching to watercooling? Will my CPU ever reach silly temperatures without being overclocked?
Should I be considering SLI? PSU will definately need an upgrade then due to the amout of 6pins available.
My budget is around £1500.
Thanks
Below are my specs:
Thanks
If nothing really is worth upgrading, should I consider going for Titan?
