Right Angled PCI-e Adapter?
2 Jun 2013
Glasgow
Hi,
Do you get such a thing as a right angled PCI-e adapter.
Its just when I plug the two PCI-e power cables into my graphics card they almost hit the side window when they bend round.
Thanks
Not seen them myself, but perhaps some braided bitfenix cables will help?
The cables are a bit more "floppy" so will bend back away from the side panel easier?
There is not heatshrink where the cables going the connector so that also helps.
Yeah I've seen erm "risers" ?
My mate was using them on his Bitcoin rigs, basically like above a large floppy looking cable with a MAle PCIe one end and a socket on the other.
EDIT: did you mean the actual PCIe or just the PCIe power cables? (its early shush :p lol)
