Re-installed Windows on my PC earlier in preparation for some upgrades, first time round it went slightly wrong, upon login it whined that it couldn't create a temporary thingy (I've forgotten, sorry
). I then tried to restore from the backup, no files copied over and the log said it didn't have permission to copy the files.
So, I did a Boot and Nuke, 2 and a half hours later that was done and I was installing again, it worked flawlessly (Which is surprising for Windows...) until I saw that it had mapped my HDD as :F.
It was fine I thought, I can just change this later, so I turned my External HDD on and it got mapped as :C
I changed the External HDD to another one fine and then I proceeded to Google a way to change the main HDD, I found a way, did it, let the backup finish copying over stuff and restarted as it said to do in the Microsoft KB.
Here comes the problem.. It gets to the 'login' screen and just hangs, presumably because I changed the boot disk's letter?
So, how do I fix this without doing another nuke and re-install please?
My PC is somewhat temperamental and it was working on that install until I broke it.
Thanks in advance!
). I then tried to restore from the backup, no files copied over and the log said it didn't have permission to copy the files.So, I did a Boot and Nuke, 2 and a half hours later that was done and I was installing again, it worked flawlessly (Which is surprising for Windows...) until I saw that it had mapped my HDD as :F.
Thanks in advance!
