basically I reset my computer to factory settings as I've been trying to sell it couple weeks or so now, but with the need to still use it as it's my personal computer and only real working windows device I started to put certain programs and games on it without worrying if they mess up, but few days ago my windows(8.1 not an upgrade) failed to boot and have been having issues with recovery, hell even putting the media disc in doesn't do much, if it doesn't show a blue screen it loops to the bios where I have to keep selecting what I need in the boot menu, in the end I had to use a smaller drive and install windows 7 which worked after a 2nd attempt so eventually I've been able to transfer what I put on my 8.1 drive to my storage ones, but now I still face the issue thinking cmd would work when I could access it via recovery option.
Cut the long story short, it's a 1tb drive and trying to get as much money for my computer as I can so at the moment I got this win 7 on a 500gb drive lol plus it originally came with the computer so factory rest is easier than fresh install from disc especially when I lost the key sticker and question whether key finder found the correct key and so looking at it in computer management I notice it has 3 partitions??
300mb recovery
260mb EFI system partition
6.35gb recovery image
Now the mb ones don't have a file system, but I have 2 identical of the image one apart from one has no file system and the other says NTFS, I also got the reserve one, but only says that in the list and not squared off.
What I want to know is what ones can I try to delete even if it needs to be forced and if I can salvage the drive without the need to format? I've only ever deleted partitions if they appeared from formatting storage drives.
300mb recovery
