Right thats it....
15 Apr 2007
Staffs
Right after much deliberation and constant hair ripping while trying to sort out my pc have come to the conclusion that my motherboard is borked!
Basically i now need a new rig and to get rid of the old stuff! After a discussion with paul_64l i have decided on getting the mozart tx case, not only for the functionality but also for the bling factor, now i just need summat to fill it with. Am going to be doing a bit of gaming but will mainly be used for my own entertainment and general messing around on. I already have an o/s and monitor, so im just looking for hardware! Either AMD or Intel not too fussed. With regards to money, not looking to spend a fortune, but i want something that will get the job done. So spec me up people!
Like i say not looking to spend a fortune so say £600 but im willing to stretch for the right machine, i might do a little overclocking once i get brave enough.
Intel Core 2 Duo E6420 "LGA775 Conroe" 1.86GHz (1066FSB) - Retail
Noctua NH-U12F (Socket LGA775/754/939/940/AM2) Heatsink
Gigabyte GA_965P_DS3P (Socket 775) PCI-Express DDR2 Motherboard
Crucial Ballistix 2GB (2x1GB) DDR2 PC2-5300C3 667MHz Dual Channel Kit
BFG GeForce 8800 GTS OC 320MB GDDR3 HDTV/Dual DVI (PCI-Express)
Seagate Barracuda 7200.10 320GB ST3320620AS SATA-II 16MB Cache
Pioneer DVR-112DBK 18x18 DVD±RW Dual Layer ReWriter - (Black) OEM
Corsair HX 520W ATX2.2 Modular SLI Compliant PSU (CMPSU-520HXUK)
Total : £688.40
Or if you drop the 8800GTS and put the:
Sapphire ATI Radeon X1950 Pro 256MB GDDR3 HDTV/Dual DVI
It would come to:
Total : £597.92
Depends if you want to start playing games a bit more. :)
That looks good by stickroad, if you want to get it a bit closer to the budget you could drop the Noctua for the moment. The stock cooler will be fine even for some mild overclocking so although the Noctua is a much better cooler overall, sometimes you might just want to stick to your budget.
Yep agree with Semi-Pro, if you drop the Noctua Cooler, the spec with the GTS would then come to:
Total : £651.98
