Will the new right to repair law cover PC parts like GPUs?
No, it's mainly for household appliances, TVs etc. A GPU would probably be classed as a component part anyway seeing as it's not actually functional on its own.
I hope nobody gets a shock opening their TV. A nasty shock if they do it wrongly.
I may be wrong, but I assumed it was from the POV of paying to have it repaired again becoming viable like the good old days, rather than just binning it and buying another.
Modern TV's are no more risky to open up than any other appliance, less so than many as they're typically operating at low voltages with the exception of the psu board(s).I hope nobody gets a shock opening their TV. A nasty shock if they do it wrongly.
You can get TVs repaired, there's nothing stopping you or any shop doing it.
Ive come across this problem. I bought a Spear and Jackson hair clippers set 3 years ago. The grade #1 attachment broken a few weeks ago. Spear and Jackson told me that the attachments can't be bought seperately so I have to throw a perfectly good working pair of hair trimmers in the bin and buy a new set.
That is a serious problem for the environment.
Wtf?Modern TV's are no more risky to open up than any other appliance, less so than many as they're typically operating at low voltages with the exception of the psu board(s).
CRT's on the other hand had a well earned reputation for being dangerous to service (and some pre 80's designs especially), because they had exposed high voltage parts.
Back on topic I can't quite see what parts of a GPU could be considered repairable outside a specialist facility (which would usually cost more than the thing is worth as a one off), with the exception of the fans and possibly cooler.
Wtf?
I repair Gpus, take a look at the gpu, there is 1000 components there. U don't Throw away gpu becoz one of those components fail.
If the law could force Manufacturers Provide schematics and board view Files, your gpu could last u 10 years and could be fixed for 50£ labour included.
Loads of components, but the ones that tend to fail tend to be either easy to fix (fans etc) or much harder to fix and hard to source especially after a couple of years, a lot of memory parts seem to go up a lot after 2-3 years as they move production to newer/faster/different parts.Wtf?
This is a good law, and I hope it grows bigger And cover More components.
know what the law covers , and I hope in.time it will expand.GPU's have 2+ years warranty and are often upgraded before it runs out so you are really only talking older ones past their warranty. Be very surprised if they are fixed for £50 inc labour. In any case most are sold on as faulty for someone else to have a look at then again the failure rate is miniscule at the side of other items like TV's etc. The law is more for mass produced items which GPU's are not they are still a niche component in the consumer world.
Wtf?
I repair Gpus
