Right...
10 Oct 2006
So I changed my motherboard to the 680i one. I have 2 HDD connected, but it is only able to detect 1 HDD. Any ideas?
double check cables/power cables. in the unlikely event you're using ide drives, might be worth checking your jumpers? :)
also have a look in the bios. are the drives showing up there?
I usually squirt a couple of twists in the middle and spread thinly - works for me - others advise just drawing a line in the middle and letting the HSF spread it on contact...
