Hi - I've just bought a Ring Pro doorbell and installation has been easy enough, the only problem is that the transformer in the box stopped working and we need to buy another (today or tomorrow morning hopefully). The issue I'm having is that "normal" transformers don't appear to fit.
In our fuse box, we have copper spikes that need to slot into the transformer and I can't find one that will accommodate the two spikes needed. I also don't understand the technical name for it which is hampering my search.
I've got photos but am having issues attaching them as they are on my laptop and so don't have a URL (if you could tell me how to do it, I can update this thread). Miraculously, the Ring transformer does fit! Ring can't get me a transformer until next week so I'm in a bit of a rush.
Please can you help? Thank you.
