Ring Size
G-MAN2004 said:
Reminding them will only make them do it more.
I know, but they are so funny, I simply adore their witticisms. Probably not as amused by them as they are by themselves but hey :)
Ernest Jones website will send you a ring size measurer. It's something like a cable tie with marking on it - put it on your finger and tighten it to how tight you want the ring, then read the size off it. they're pretty accurate BUT FOR THE BEST MEASUREMENT GO TO A JEWELLER.
To get the correct size, you need to be measured using a ring sizer that relates to the width of the ring you are going to purchase. Some people find that they are different sizes for thin rings and wider, band style rings.
