Hello,
I am looking to update my current rig, I am going for the black and white theme but need a hand with a couple of things... (ignore the blue LED fan this is getting replaced)
1. I can't bear the cables above the Mobo for the front header and usb 3 - any ideas on how I can make them neater?
2. The AIO pipes are going to be moved higher once I replace the blue LED fan... any better orientations?
3. I have the cooler master master fans ARGB 120mm (over sight and should just got normal RGB as my last Mobo died and replaced with the MSI mortar H270 arctic) any ideas on how to keep a static colour of white? It pulses at the min and tbh I know I am asking here and will ask in the correct area if not etc... any help would be great and they are controlled by a hub that came with the triple pack.
4.the PCIE cable will be replaced with a white extension soon....
Spec - I5 7600K, MSI H270 Mortar Arctic, GTX 1070 all in a Riotoro CR1080 case
