Rip Gsync (FastSync?)
1 Nov 2013
Is this RIP Gsync?
/me waves goodbye to his resale value of 4k gsync
It's not as responsive as vsync off in terms of input lag, but very close and no screen tearing ? - any info on this vs gsync?
Does the same job as Vsync with reduced lag. Gsync is the other half of your video card you never got in the 1st place while Adaptive Sync is a industry standard version of Gsync for people with fully developed cards.
I'll get a sore head if I try to explain it in any more detail ;)
From Gamespot:
With the GTX 1080, Nvidia is also introducing a GPU/display feature called “Fast Sync.” It's a complementary feature to the company’s G-Sync technology, but does not require a G-Sync monitor. The benefits of Fast Sync come into play at the higher end of the performance spectrum, when your GPU is able to render frames faster than your monitor’s refresh rate. Enabling Fast Sync here, in theory, would allow you to get near the low latency of having V-Sync disabled, but without the annoying screen-tearing effects.
So it's only any good if you can drive the FPS above your monitors refresh rate.
They claim it reduces input within ~10ms of vsync off but you get no tearing which is a win win!
My question is how does the input latency compare to gsync input latency. Gsync will limit your FPS to the max refresh rate of your monitor, in my case 60.
Its not the same as Gsync at all though...
It will work at the monitor refresh rate eg. 60hz, 144hz or whatever it is....
And your FPS will have to be higher than the monitor refresh rate...
Gsync will sync the monitor to whatever your FPS is from 30-144hz with no tearing or lag.
But yes fast sync looks good if you play CS:GO or something at 300fps and want no tearing or lag, or it might still be better to run at 300fps Vsync off for the lowest possible lag.
But not a replacement for Gsync at all.
its prob a little bit less latency than g-sync...hence the name
as i understand it g-sync has to send a ping back, this doesnt
No, it doesnt.
With gsync the gpu spits the frames at the monitor as fast as it can and then the monitor controller sorts out the rest
That infamous gsync latency test that Linus did, in the video he says he turned vsync on and off in game... thats not how you do it with gsync, it should always be off in game
No, it doesnt.
oks! ive learnt not to argue with a guy in sandals
i duno why its called fastsync then! i guess freesync was taken!
<3
I agree with some of what you say. I play cs:go at 60fps/hz gsync. with fast sync you can get 240fps in 4k WITHOUT screen tearing which is essentially what gsync does.
Gsync solved the problem of screen tearing with vsync off and input lag with vsync on. In summary i think the only difference is fast sync wont limit your FPS but will give the same result as gsync.
From what I read it replaces gsync
I've just been watching this video and the guy explains that fastsync is best used when the render rate is above the refresh rate and gsync is best used when the render rate is below the refresh rate. at the 9min 30 mark.
I still think this could be the end of gsync though!
The thing is .... i have tested cs:go limited to 59fps on my 4k gsync with gsync off and vsync off but the game limited to 59 fps and it isnt anywhere near as smooth as gsync on. This is where gsync comes in i believe.
Tom peterson said specifically do NOT use fastsync if its above 60fps on a 60hz monitor. So i dunno where people are getting that you need to drive your fps up past what your monitor can do. He said its good for when its under 60fps but not at or over 60. He said this on pcper stream the other day.
Why not if you want to prevent screen tearing and input lag on a 60hz monitor? e.g. i want to play cs:go at 300fps on a 60hz monitor without screen tearing? why not use fastsync as this eliminates screen tearing and the negative impacts of input latency when using vsync?
This doesn't replace GSync. FastSync is used to eliminate screen tearing in situations where the game's framerate is far greater than the monitor's refresh rate, but without the input lag of VSync. The feature is built into the card and does not require a monitor with special hardware. Unlike Gsync, you cannot use FastSync in situations where the framerate dips below the refresh rate, as that will only lead to stuttering, just like Vsync.
FastSync...
No. No, you are not allowed to do that. :p
Ah so.... fastsync can't work when render rate is below refresh rate as this causes stuttering, which gsync resolves.
I already get a sore head trying to decipher your posts :confused:
Why I am the only one that sees VESA's Adaptive Sync description from NV? Or more commonly named Freesync? :D
