Hi Guys,
The Raijintek Pallas turned up for my SFF xeon build, but sadly it won't clear the first DDR slot with the Ripjaw in.
I want to use this cooler, and I am not going to buy more ram, so I have a few options:
a) Cut the top of the heat spreader down (3-5mm should be plenty off of the top 'fins')
b) Remove the heat spreader and replace with a lower profile one
C) Remove the heat spreader totally and just leave it
What would you do?
TBH the RAM is probably worth like 15-20 a stick so it's not exactly going to be an issue modifying it (I doubt anyone would want to buy them later if I changed the system but hey).
Also really does it need the heat spreader and is it worth buying another?
Cheers!
What would you do?
Cheers!
