-V 1 --vbr-new --add-id3v2 --pad-id3v2 --ta "%a" --tt "%t" --tl "%g" --ty "%y" --tn "%n" %s %d -k
hungryhungry123 said:If your hard drive can take it, Id recommend going straight up to 320kbps. I ripped a load of CDs at 160 or something liek that, got some new speakers, realised they sounded poor so decided to rerip (8 hour nightmare). The way I see it, if you do 320 you're covered for future hardware upgrades![]()
Bes said:I can usually tell the difference between 320K and anything lower on my hi-fi (maybe some are poor rips or source thoug and some music seems to rip better than others at lower rates), but I don't really see the need to go any higher.
(Mind you some of the CDs I own *Cough Editors *Cough Cooper Temple Clause) sound like they were created at 128K anyway!!![]()
Hey hang on a second... Don't you accuse me of piracy here- every piece of music ever played on my hi-fi has been bought.james.miller said:i'm going to be frank here, all the music you rip should be ripped to the same standard. the lesson is - rip your own music, because its pretty obvious you'd only say what you just did if you were talking about music you have downloaded. To be honest, most of the stuff you can find on the net isnt ripped to any standard what so ever.
So are you saying 'sure' I can hear a difference or am I still pirating music in your eyes? Do you actually want to have a proper discussion about this? What are you basing your post about 224 being optimum on?james.miller said:sure![]()
Bes said:So are you saying 'sure' I can hear a difference or am I still pirating music in your eyes? Do you actually want to have a proper discussion about this? What are you basing your post about 224 being optimum on?
I think that's really the best advice, especially if one is thinking about ripping at 320kbps CBR. Hard disk space is so cheap now - like 20p/GB - that it seems to make so much more sense to go lossless. No need to have any concern about quality, and infinitely more flexible. Having said that, at ~400MB per disk, I can see why people who are interested in high quality audio might still not be convinced when 192VBR/LAME can have excellent results.james.miller said:If you have plenty of space, think about using a lossless codec such as flac or monkies audio
Not really. if you want to be covered, use lossless. then you can convert it to any losses codec and you'll always be covered for the future.
I'm not sure, I've been using Audiograbber for a few years now, but you can just download the Lame.Dll and place it in the Audiograbber install folder.james.miller said:does audiograbber still come with a very old version of lame? (3.5 i think).....its not a patch on 3.97!
maybe so, but Audiograbber does what I require right nowjames.miller said:you still need to use the command line parameters to get the best out of it![]()
