I'm mainly an iTunes user (i know, but i use mac and windows
) and i have loads of different rips in different quality and in different places, so my music files are very unorganised.
I want to rip everything in a lossless format, which can be tagged for viewing in iTunes and be used across iDevices without the use of additional apps.
Storage isnt a problem, and i know some formats are larger than others.
FLAC then, is a no-go as iTunes doesn't support this.
AIFF looks a good option, but i think there are problems with tagging?
ALAC (Apple Lossless) seeeeeems to be the better choice, and appears to be a proper lossless format.
WAV I'm not sure about, the tagging seems a but off in itunes, and I don't think it carries artwork?
But if I chose ALAC, could this have repercussions if i were to get an audio streamer from the likes of logitec, ARCAM, Teac etc...?
Do most systems like ALAC, or is this only licensed for apple software/hardware?
Im using DbPoweramp, but I do have EAC and another good program (forgot the name
Music will be played through a decent HiFi from my Xonar DX and streamed from a readyNAS Duo.
Using one format for everything is my aim, because im fed up of having a messy music folder with different fomats and wrongly tagged tracks
Sorry if this has been covered countless times, but when googling the subject, people are saying to use all kinds of alternative players and rippers
And i hope this is in the correct section!!
Thanks for any suggestions....
) and i have loads of different rips in different quality and in different places, so my music files are very unorganised.I want to rip everything in a lossless format, which can be tagged for viewing in iTunes and be used across iDevices without the use of additional apps.
)Music will be played through a decent HiFi from my Xonar DX and streamed from a readyNAS Duo.
. It supports metadata, is open source and supported by XBMC to
