I have just started using RIS as some of you suggested and it works great but I have hit a problem now.
I can build a laptop using RIS with no problems. I then add all the programs I want. I then run RIPrep and all the files are copied to the server.
When I go to another identical laptop I should be able to boot from LAN and find the new image a load it from there right? However it then says that the OS does not have the right drivers for the network card.
I had to modify the files to get it to work the first time but what do I need to edit in order for the RIPrep image to work??
