Also a way to disable driver signing in vista 64 for good, cos it needs to be disabled for riva tuner to run. Always prssing f8 befrore windows loads is a joke to disable it, there must be a easier way?
if you make a profile in catalyst after turning on Overdrive( make sure clock and memory settings are correct). You can then go to the file "C:\Users\Bretware\AppData\Local\ATI\ACE\Bretw are. [COLOR=#000080 ! important][COLOR=#000080 ! important]XML[/color][/color]. the xml file will have the same name as the catalyst profile you saved. right click and hit edit.
<Feature name="FanSpeedAlgorithm_0">
<Property name="FanSpeedAlgorithm" value="Manual" />
</Feature>
<Feature name="FanSpeedRPMTarget_0">
<Property name="Want" value="0" />
</Feature>
<Feature name="FanSpeedPercentTarget_0">
<Property name="Want" value="65" />
Change the value to "manual" and Want value to "65"
Save the file then reload your profile in catalyst.
65% seemed perfect for me, 70% was loud but you may need it if your case has poor air flow.
You will have to select the profile everytime you start the [COLOR=#000080 ! important][COLOR=#000080 ! important]computer[/color][/color], but it will work until there is a fix or better info so i can figure how to change the auto target temp.
Good Luck ,bretware
It protects itself from PB, so it won't kick you from servers.
sure..it works on mine but with a different system and that..
Well I would change the cooler then if it's so noisy ..you can get them for a cheap price and they're very easy to fit.![]()
