riva tuner statistics not showing in games fps/gpu/cpu temp
17 May 2016
can any help me please rivatunerstatistics is not displaying any info in game for me ie fps/gpu/cpu temps. I belive ive got it all set up correct I had it display all the info first when I set it up now nothing is showing up. please help
I hope so mate spent a lot of money on it so far ;-)
still having problems today I cant get the riva tuner stats to show up when playing games any ideas please ?
Do you mean you're still having problems displaying the overlay?
What's your system spec?
Yeah it was working perfectly other day after I thought I had to have msi afterburner open for it to work went to use it today and it's not working I haven't changed anything opened msi afterburner like other day but is still not working. What spec would u like to know mate?
It's ok - i thought perhaps you had a compatibility problem but you had it working so it can't be that.
I would re-check all the tick boxes you need within settings (re-apply ideally) and save. Test again.
Also do you have AFterburner load up with your computer?
No I don't have afterburner load up with computer. But the other day after I figured out I need afterburner open for the overlay to display I manually opened it before I opened the game I wanted to use the overlay on.
