Rivatuner 2.08 help
24 Aug 2003
Gillingham Kent
Just installed this on Vista64 now I can't find the settings for overclocking and fan control. Any help
Gary
umm low level customize button first icon has fan control and the second icon is overclocking i believe. The customize buttons flash if you havent clicked them yet (which you probably have) hang on theres a thread i used to set up my fan profile ill see if i can find it.....
edit - http://www.vaguesoft.com/index.php?pageid=rt207
my 8800gtx came with the worst fan profile on it i dropped 10 degrees in both idle and full on by setting up my own.
going to take a look cheers
Yes my rivatuner does not have the 'driver settings' menu where it says forceware detected
Had a similar problem the other day on my rivatuner, and once I reinstalled it the menus/buttons all returned. God knows why, but it works now.
