RivaTuner + 2900 questions
24 Jan 2007
hi
im using RivaTuner to monitor the temps. i just notice theres a voltage regulator temperature which goes to 71c under load, is this normal?
Hey,
That's no problem, don't worry, those things used to go upto 98 degrees on mine because I'd replaced the cooler on the Core but I hadn't put anything on the Voltage Regulators.
Don't worry about 71 degrees, that's not a bad temperature for them :)
Banjo
ok. thanks guys.. i was asking because last night it had afew problems while gaming but i think it's due to the 8.6 drivers. so i may go back to 8.3 driver.
