RivaTuner adjust fan speed while in game
2 May 2004
Hi,
I'm running Rivatuner 2.09 under Vista using the Launcher/Scheduler method to adjust the fan speed when the temperatures reach a certain level.
I was just wondering if there's any way to make it so the fan speed is adjusted when a certain .exe is run (like you could in nTune... the concept was there but it never worked :p).
Thanks,
Craig.
That was all changed from v2.07 onwards apparently. The method above doesn't work for me, so I'm using this method: http://www.vaguetech.com/index.php?pageid=rt207
Works in the same way, but from different sections of the program.
I'm just lazy, I'd find it a lot easier just having the fan spin up to 100% when in a game, and normal when out of game. Maybe I'll just spend some time sorting the speed control.
