RIVE with ancient bios upgrade.
Man of Honour
21 May 2012
Dalek flagship
I have an old RIVE with a really old bios that I want to update.
IIRC I can not go to the latest bios in a single step but must upgrade to a slightly newer bios first.
My problem is I can not remember which bios version I must upgrade to first.
Thanks.
Looking on the web page for your board the download for bios versions 2002/2003/2105/3301 states "*If your BIOS version is 1404 or older, please install the BIOS Converter first before you update the BIOS. The BIOS Converter is available in the BIOS Utilities*" This converts the bios from .ROM to .CAP. Once you have done that you should just be able to download and flash the latest bios which is 4901.
