RIVF 3820 OC template help!
14 Apr 2009
Cheshire
Hi all,
I've set the strap to 125 and it seems to be booting and reporting 4.6ghz.
CPUZ is reporting 1.5v though! This is high no?
What should I set to CPU voltage to for this frequency?
I'm struggling with the new bios (coming from a p6t deluxe v2) ! Where is CPU voltage and multiplier? I want to manually set that to 37 too, but can't find it.
This looks useful: http://forums.overclockers.co.uk/showthread.php?t=18393540
Ok. I've only set the multiples and the strap to 37 & 125 and IBT fails on the 2-3rd run.
What is the next step?
My teamgroup 2133 ram is set to 2000.
Extreme Tweaker Menu
Ai Overclock Tuner: Manual
CPU Level Up: Disabled
Bclk freq: 125.000
CPU Strap: 125MHz
ClockGen Full Reset: Enabled
Turbo Ratio: By All Cores
By all cores : 37
CPU Clock Gen Filter: Auto
Memory Freq: DDR3-2000MHz
Extreme Tweaking: Enabled
EPU Power Saving Mode: Disabled
Extreme OV: Enabled
Bclk Skew: Auto
CPU Vcore : Manual Mode
CPU Vcore Voltage: 1.395
VTT CPU Voltage: 1.15000
2nd VTTCPU Voltage: 1.15014
CPU VCCSA Manual Voltage: 1.15
CPU PLL Voltage: Auto
PCH Voltage: Auto
VTTDR Voltage (A, B): Auto
VTTDR Voltage (C, D): Auto
CPU Spread Spectrum: Disabled
PCIe Spread Spectrum: Disabled
Digi+ Power Control Submenu
CPU Load-Line Calibration(LLC): High
CPU current capability: 180%
CPU Voltage Freq: Auto
VRM Over Temperature Protection: Auto
CPU Power Duty Control: T.Probe
VCore MOS voltage Control: Auto
CPU Power Phase Control: Extreme
CPU Vcore Boot Up Voltage: Auto
VCCSA Load-Line Calibration(LLC): High
VCCSA Current Capability: 140%
VCCSA Fixed Freq: 300
CPU VCCSA Boot Up Voltage: Auto
CPU VTT Switching Freq: Auto
CPU VTT Over-Current Protection: Auto
DRAM-AB Current Capability: 100%
DRAM-AB Voltage Frequency: Auto
DRAM-AB Power Phase Control: Auto
DRAM-CD Current Capability: 100%
DRAM-CD Voltage Frequency: Auto
DRAM-CD Power Phase Control: Auto
PCH Switching Freq: Auto
CPU Performance Settings Submenu:
CPU Ratio: 37
Enhanced Intel Speedstep Technology: Disabled
Turbo mode: Enabled
Power Limit Control: Auto
Advanced Menu
CPU Configuration Submenu:
Intel Adaptive Thermal Monitor: Enabled
Hyper-threading: Enabled
Active Processor Cores: All
Limit CPUID Maximum:
Execute Disable Bit: Enabled
Hardware Prefetcher: Enabled
Adjacent Cache Line Prefetch: Enabled
DCU Streamer Prefetcher: Enabled
DCCU IP Prefetcher: Enabled
Intel Virtualization Tech: Enabled
CPU Power Management submenu
CPU Ratio: 37
Turbo mode: Enabled
CPU C1E: Disabled
CPU C3 Report: Disabled
CPU C6 Report: Disabled
CPU C7 Report: Disabled
Monitor Settings
Anti Surge Support: Disabled
I can run through IBT 10 times on Standard every now and again, but more often that not it crashes. Temps hit 71-75 across the cores.
Any suggestions?
Sure you dont need extreme ov enabled
Dissable turbo.
Set cpu pll volts to 1.65v
Cpu loadline calibration to medium
Cpu current C to 140%
Vcore mos volt to 7
Vccsa llc to regular and current capa. To 120%
Dram current capa. To 120% and power phase to optimised on both.
Leave secondry volts for vtt on auto
Dissable turbo.
Vcore mos volt to 7
Hi Nick.
Just tried those settings. I ran through IBT 10 time standard, and it worked. Ran again and it failed!
Perhaps Ive got a bad chip!
I've also tried to just set the multiplier to 43 and leave bclk and strap to 100 but it will not POST.
maybe I have a bad chip?
At stock I've run through IBT twice with success.
IBT = Silicon torture POS!!! Use your PC to test stability or maybe Prime blend for 20 mins then use.
Nic has done a good job although I think I have seen those figures before;)
As far as the rest goes. Tune VCCIO and VTT. For DDR2000 1.1 on each is a good start. Set up Rampage Mode1 on memory.
What are your temps loaded as this can effect your clock quite a lot. All 3820 I have had do 4625mhz + . Take your time tuning.
Hi 8 Pack. Thanks for helping.
Good to know that it is more likely my incompetence rather than a poor quality chip!
I've done a few things since going back to stock (went to stock to ensure everything seemed stable):
1. I've installed the mobo intel chipset drivers from the Asus site. I hadnt done that at all and just assumed Windows 7 would do it. Maybe it did, maybe it didnt. Would that affect an OC?
2. Ive set the strap to 125 (bclk defaulted to 125 then)
3. I've set my RAM to 1666. Although it is teamgroup xtream 2133. I've not touched anything to do with RAM other than set the speed. Is this a bad idea when trying to OC the chip?
4. Run IBT 3 times (10x Standard) and it did not fail.
It seems that there are two places to set the multiplier? Under CPU ratio (seperate option screen) and also under Turbo Ratio, once set to manual from auto? Where should I set it? I also think I want to turn off speedstep and turbo mode on the 4th picture.
I'm also wanting to reduce the AUTO voltage, as it hangs around 1.505v a lot and seems hot.
My temps under load (IBT) do go up to 80ish (max on realtemp was 84). But that is surely because of the AUTO cpu voltage at 1.505.
I shall no longer use IBT, and use 30mins of Prime to test stability.
I shall also set my memory tweak to mode 1.
Have you read 8Packs x79 guide??
For your ram manually type in your sticks rated timings and leave rest on auto, and set too recommended voltage and rated speed.
As 8pack said earlier set rampage tweak to mode 2
And for now set latency boundry to auto and once its running ok try nearer.
Give your cpu a little voltage bump if its failing IBT.
Also in control panel, look for power options or type it in search bar and set too performance.
Have you run memtest to check your sticks??
Hi nick. yes read the guide and while I work in IT it made little sense, although I think I'm understanding more.
Timing say cl9-11-11-28 1.5v so ill enter them in.
Also I'll do the tweak to mode 2 and run memtest...
Report back soon.
Thanks for all your help!
Rampage mode1 I suggested!!
I would stick with this first up.
Running memtest now.
Where do I set multiplier?
Under CPU ratio (separate option screen) or under Turbo Ratio, once set to manual from auto? I think I would just like a fixed clock, rather than it jumping around as if it was in control.
Update!
I've ran memtest and it came back O.K.
Here was my memory just allowing the mobo to do its AUTO job.
These are tighter timings than the memory is rated for so, I set all the values and also set the mode to 1. The next picture shows the rated timings.
In the next picture what does the tighter timing JDEC 3-5 mean? The last one XMP looks to be what I set it to.
Still worried about the temps. Below is after two runs of IBT standard...., check out the max values looks hot!
IBT waste of time waste of time waste of time!!!
RAM looks fine though!!!
Thanks!
My plan for the temps is to manually set the voltage to 1.48 and then drop 0.05v until is starts misbehaving then up it a little.
That seem sensible?
I've disabled EIST, but left turbo on as otherwise that removes the Turbo Ratio on the first page.
I've set that to By All Cores, and put in the value of 37.
I've also set the cpu vcore voltage manually to 1.395v.
This has been stable in prime for 21minutes then I got bored. I've also ran IBT to get the max temps of the chip, and it was cooler than prime95
I think this looks ok!
I had the vcore voltage at auto and it would always sit at 1.5v which apparently is way too much. You don't think this will have damaged the chip in anyway over the few hours of testing at that voltage?
Just an update. I've managed to set the following:
VSSCA to 1.15v
VTT CPU Voltage to 1.15v
CPU PLL 1.8v
vCore 1.365v
strap of 125
bclk of 128
multi of 37, by all cores.
RAM is set to 1.5v with CL9-11-11-28-1T timings (basically as spec).
This gives me a healthy 4,736MHz and a 2048MHz for the RAM.
Everything is stock (i.e Auto)
I've run prime for 20min and a run through IBT x10 standard. All seems sound. So now I'm just going to wait it out and use the machine as I usually do and if no crashes them I'm stable imo.
If it remains stable I'm interested in understanding more about the LLC settings and what they really mean.
But for line in the stand, this looks good enough to starting using my new machine in anger yes?
Use the PC. Stop with the synthetics, Is your LLC at medium??
You dont play IBT!!! it degrades CPU.
Otherwise looks ok.
