- 26 Sep 2005
- Midlands
Has anyone had any experience installing Rizoma Reverse Retro Bar End Mirrors?
I just installed a pair along with some Rizoma Bar End Weights and there's something I'm not sure about.
Specifically, the Rizoma Bar End Weights come with rubber expanders. I installed those first then opened the up mirror boxes.
Inside the mirror boxes were metal expanders. The Rizoma instructions are **** but I could make out in the pictures the metal expanders replacing the rubber ones.
I just wondered if I should bother taking the weights out again to replace the rubber expanders with the metal ones?
I'd have thought the rubber expanders would help reduce vibration on the mirrors a tad, but I don't really know what I'm on about
Any advice greatly appreciated
