- 24 Jul 2009
Hey all, quick question on RJ45 and cat6 cable (Yes I know cat6 is overkill for home but I didn't have to buy it and it was the only one available
I know the RJ45 connector is the same size but I have seen that on some, the ends are staggered rather than in a line. Can I use a RJ45 connector that makes the ends of the cat6 cable flat in the connector instead of them being staggered high then low etc (if that makes sense, not sure how to explain properly).
If I can, I assume that the actual speed will still operate at it's maximum capacity? 1Gb is all that is needed.
Thanks.
Thanks.
