RJ45 crimp tool recommendations
28 Dec 2002
South Coast
Looking at Easy RJ45 Crimp Tool, but also interested in other recommendations etc for Cat 6 RJ45 cable terminations
best thing to do is to read the reviews on the product page.
Spent a while looking at the 3 star reviews to see the best and worst crimper.
Got a moderately priced one in the end that works well enough but isn’t amazing.
I've been using the VCE pass through one from Amazon for a while now with no issues.
Depends how much use you intend?
I bought a cheapish Amazon one was fine for my home wired network.
If you are planning on becoming a network engineer professionally that's a different story.
There's a bunch of crimpers on eBay that look identical to the CCS "Easy RJ45" crimp tool except they are about 25% of the price. If I only had to do a few jacks I'd probably start with that, it looks decent enough.
If I had to crimp loads of jacks then that's a trick question because I'd just insist on being bought patch cables. There's very few situations where I can think of having to crimp a plug onto a cable, maybe for video distribution where you're trying to limit the number of drops, or for wireless APs where you can't install the AP over a pattress box and put a keystone in behind it.
