My computer downstairs will not "click" at all into place when I insert a network cable. Anyone else have this problem? Its stupid because it means there is nothing stopping it from coming out...
If the clip on the cable is fine then its the socket, the part on the socket that keeps the cable in is very very small in the region of 2 1x1mm protusions, if these are knackered then basically its unfixable.
The socket will still work.
My dad had the same issue on a old PC (as above it was the clips which were worn) we just made sure the cable was packed up to the wall so it couldn't physical fully come out. It worked a treat.
Well I'm king bodger so would probably tape it or maybe even a tiny dab of superglue depending on how permanent you want things.
Can you wedge it I'm with some cardboard?
