Rm1000x 3 Pci to 8pin connectors for 3080ti
25 Nov 2004
london
Got a Corsair CP-9020094-UK RM1000x 1000 powering my 3080ti. Using 3 separate cables so have 6 6+2pin (looks messy) connectors is there someone making 3 x pcie to single braid to 3 x 8pin connector. Don't know if I've descripted this very well, want to cut down the mess.​
Cheers.
Yep there are a few brands around that manufacture fully modular PSU cables, which includes single 8 pin PCIe cables which is what you're after (so there is no additional pig-tail 8 pin).
CableMod are popular and OcUK sell them amongst other places too, but they are quite expensive imo. There's a fairly famous Asian based retail site that sell brands like FormulaMod and Winkool (who I've used several times) that make them a lot cheaper.
I've only just ordered another set for a family member last weekend infact, also for his RM1000x. I got a fully modular cable set from Winkool for £60 delivered - which includes the 24 pin ATX, 8 pin CPU, SATA and 3x PCIe 8 pin cables.
(so there is no additional pig-tail 8 pin). so couldnt think what its called. awesome. What you do for braiding them together
If you have the space to hide the extra cable length cable extensions are a much cheaper alternative and fit all psu's as they just clip onto the end of the existing cable. I currently use ones I made myself but have used Phanteks and Bitfenix extensions in the past with zero problems.
You can get a pack of cable combs for £1/2 depends on material you go for. Plastic being cheapest, aluminium ones are nicer but few quid more.
As mentioned above though, if you have a case with loads of space to manage cables - extensions are a cheaper alternative. But personally I find most cases unless you have a full tower, always benefit from just going full modular swapping out the full PSU cables - looks much neater imo for not much more. :)
Buy some Braided extension cables and a few 24 power cable combs, that's what I did for my 3080 looked way better.
