RM850 + Cablemod Inquiry
4 Jul 2006
I was thinking about picking some sleeved cables up as they will be easier to work with than the standard but I think im just confusing myself a little.
Does this come with enough cables for this PSU and an MSI Z690 which according to manual has 2 cpu power slots on board.
If I am reading it right its only 1 cpu power cable I think.
The 2nd 8 pin on the board is optional. Mainly needed if doing heavy overclocking.
oh I see, been nearly a decade since I last upgraded and had no idea lol. Going by the manual I assumed this was the default now, I appreciate you getting back to me. My refund on my case came through so I can order another and cablemod kit.
Anybody mind double checking my paranoia that that is the correct kit, if not ill give OC a ring tomorrow.
I barely overclock let alone heavily overclock so I should be good.
Edit
Looks like it isnt for the bog standard RM series.
Think this is the one.
https://www.overclockers.co.uk/cabl...-rmx-and-rm-black-label-carbon-cm-16l-cm.html
Edit
They look correct to me. Also you get 2 x 8 pin cpu cables as well by the looks of it, so you have the option to plug both in if you want.
