Hi
Just signed up to this forum in the hopes someone can help me out or point me in the right direction as to what to do here.
So, I have an Aorus 1080ti GPU, which recently has begun crashing under stock clocks, and power limit. the second I under clock, moving the core and memory clocks down, as well as power limit, it runs fine. The performance has also been noticeably worse.
I spoke to a friend who tested everything for me and has told me to try and RMA the GPU, as that seems to be the problem. Unfortunately, my uncle who gifted the GPU to me passed away last September. I have no access to the invoice, which is required by Aorus. I cant seem to find a phone number or such to try to call Aorus and explain the issue.
I dont have the box to the GPU, and cant seem to locate the check number on the actual GPU, wanted to know if there was anyways to find the check number from the actual gpu.
Any help is much appreciated.
Regards
Jumz
Regards
Jumz
