RMA'd Ballistix replacement advice
30 Oct 2005
Hi,
I sent my 2gb as an RMA to Overclockers today. With this boot issue that many have discussed on the internet.
I'm looking for advice for a replacement 2gb kit to fit in my system. Asus A8N Premium, Athlon64 3700, BFG 7800GT, Seasonic600w. I have £160 before vat against the ballistix.
I had a good overclock to 2.8ghz with the system when the ram was new, but it has been at stock for 2 months now. Be nice to be able to achieve this again but I might also run at stock for the time being.
The shop have been great, good to be able to phone and speak to the strore on the phone now. Corsair is recommended by the store, as it is approved by Asus. GSkill was also recommended with Asus boards.
I was looking at the following;
Corsair 2GB DDR XMS4000PT TwinX (2x1GB) CAS3 (MY-094-CS)
A matched pair of 1GB XMS4000PT memory modules - 2GB total - ideal for dual DDR motherboards. Memory timings of 3-4-4-8. Ideal for overclockers or those who need to run their memory at high frequencies then this is the memory kit you require.
Price: £133.95 (£157.39 Including VAT at 17.5%)
OCZ 2GB (2 x 1GB) PC3200 Dual Channel Gold GX XTC Series EL-DDR CAS2 (OCZ4002048ELGEGXT-K) (MY-059-OC)
400MHz DDR
- CL 2-3-3-8 (CAS-TRCD-TRP-TRAS)
- Unbuffered
- Gold Layered XTC Heatspreader*
- Lifetime Warranty
Price: £159.95 (£187.94 Including VAT at 17.5%)
OCZ 2GB (2 x 1GB) PC3200 Dual Channel Platinum Series EL-DDR CAS2 (OCZ4002048ELDCPE-K) (MY-057-OC)
OCZ Platinum Edition PC-3200 memory is specifically designed for ultra-low latency timing operation on both Intel and AMD chipset based motherboards. OCZ Platinum Edition PC-3200 memory is able to reach latencies as low as CL 2-3-2-5 or even lower depending on the specific motherboard! Every Dual Channel Kit from OCZ is hand tested as a matched pair across a wide variety of motherboards to ensure flawless performance on most motherboards. Each OCZ Platinum Edition module also comes with a high quality copper heat spreader with a Platinum mirrored finish that not only helps dissipate heat, but also looks great in a windowed PC case. Finally, OCZ Platinum Edition memory modules are rated to handle up to 2.8V without invalidating the OCZ Lifetime Warranty so that performance enthusiasts can tweak their systems without worry!
- 400MHz DDR
- CL 2-3-2-5 (CAS-TRCD-TRP-TRAS)
- Unbuffered
Price: £139.95 (£164.44 Including VAT at 17.5%)
G.Skill 2GB DDR ZX PC3200 (2x1GB) CAS2 Dual Channel Kit (F1-3200PHU2-2GBZX) (MY-007-GS)
GSKILL successfully launched high performance ExtremeMemory Series memory modules in 2GB, 1GB and 512MB capacities. ExtremeMemory Series consist of dual channel and single channel series. GSKILL continues to utilizes the latest advanced technology in product development. The high performance ExtremeMemory Series is engineered for superior performance in an extreme environment. GSKILL 2-3-2-5 SERIES Dual Channel Edition PC-3200 memory is specifically designed for high frequency operation on Intel 865/875 and Nvidia Nforce 2/Nforce 3/Nforce4 chipset based motherboards. Through the use of G.SKILL .
***Stunning Low Price - OcUK Exclusive!!***
- Package : 2048MB kit (2x1GB) dual channel pack
- CAS Latency : 2-3-2-5 (PC3200)
Price: £129.95 (£152.69 Including VAT at 17.5%)
