Road bike help
19 Jul 2006
Leicester
Hi,
Been looking at getting a road bike for a couple of years now and only really now looking properly. Going to use the cycle to work scheme to get it discounted but have no idea what to get!
Been looking at bikes in Evans today but only really been going on price. I'd be looking at spending £800 before discount.
Saw this nice Fuji one http://m.evanscycles.com/products/fuji/roubaix-13-2015-road-bike-ec069089 but never heard of them.
Also looked at the Specialised Allez which was around £500 and some Trek 1 series 1.2 which was £650 odd which to me seemed decent.
Any help would be great, thanks.
Is your bike to work scheme limited to one or two shops? A lot of places seem to do that, makes it a bit awkward. Fuji bikes are generally alright, they're more of a budget brand in the US. I can't recommend the base level Allez as it has aluminium forks, but any of the rest of the range should be fine. The Trek is nice but a bit overpriced for what it is. On Evans i would definitely suggest looking at some Cannondales, the CAAD8/Synapse ranges are quite highly recommended.
Are you going to be riding exclusively on roads/light trails? What do you want to do with the bike?
I'm not sure if the scheme is limited to a couple of shops, I don't think it is, but I'm going to sign up when I go back to work in a couple of weeks.
It'll be used just for road riding and keeping fit. Lengths of ride would be between 20 and 50 miles once I get my fitness up again.
Just had a look and there are so many different Cannondale CAAD8 and Synapse bikes...
Yeah the Synapse is a lot more upright than the CAAD. I have a CAAD10 and it was quite uncomfortable at first, but now I really like it.
If I bought again I'd probably have bought a Synapse, but I still don't really regret my decision... it just took a bit of getting used to.
Pretty much set on this bike now...
http://www.evanscycles.com/products/trek/domane-23-2016road-bike-ec068734
Should be buying within the next couple of weeks.
It's not carbon, but aluminium will be fine, has a good group set and positive reviews. Also, it's suited for long distance, relaxed rides, which is what I wanted out of the bike.
Any other suggestions before I buy? Thanks for any replies.
