Quick help please if you guys would be so kind.
The recipe states to cook the beef for 50mins per 500g, so if i had a single 1kg slab obviously it would be in for 100 mins - but what if I have 2 seperate 500g joints in the same roasting pot, I just cook them for 50 mins total right?
I'm finding conflicting information
And then I found this:
I think I should buy a meat thermometer! But for some quick advice for today's Sunday lunch, what are people's opinions?
I'm thinking if I have them spaced properly in the dish then I should be cooking at the single weights time and not for double? So simply 50mins...?
Cheers
Cooking times ought to be very similar because the oven radiates (a lot of) heat. Surface area doesn't generally enter into it unless you're cooking stovetop, in the oven it's volume that matters.
The time that it takes to roast something is based on the time it takes to get the internal temperature to "cooked" depending on how you like it. The bigger the roast, the longer it takes for the internal temperature to reach the correct temperature. It is based on the distance from the outside to the inside on a roast, so two 3 pound roasts will take a good bit less time than one 6 pound roast. By contrast, if you have a very flat thin 6 pound piece of meat, it will take less time to cook than the 3 pounders.
Suppose we have two roasts with exactly the same combination of identical tissues, and the same shape except that the one is a scaled (blown up) version of the other. Let's weigh both roasts and compute the ratio between the two weights; let's call that ratio r. Suppose furthermore that the roasts have the same starting temperature, and we will cook both until they have both reached some given (higher) temperature at their centre. What can we say about the times that both roasts need to cook for?
The answer is that under these assumptions, the bigger roast will need r^(2/3) times as long as the smaller one.
So, assuming each small roast (700 and 950 grams) has the same shape as the big one that the recipe writers used (let's say 1750 grams), for the 950 gram roast you'd expect to use (950 / 1750)^(2/3) = 0.665 or about two-thirds of the cooking time, and for the 700 gram one you'd expect to use (700 / 1750)^(2/3) = 0.543 or just over half of the cooking time. In particular, for the 950 gram roast, you should expect to roast it at 200C for 20 minutes, then turn down to 180 and roast for around 0.665 * 1750 / 450 * 12.5 = 32 minutes more. (1750 / 450 * 12.5 = 49 minutes is the average time they would recommend for the 1750 gram roast, and we're using that as the base for comparing our 950 gram roast against.) Then check with your thermometer!
Cheers
