Hi,
So Black Friday is upon us and we have decided to launch some deals nice and early so you have a chance to grab an early bargain or two. So below are a couple of deals that we are launching early so take a look and hopefully grab something you had your eye on but at a better price.
More deals will be added over the course of Black Friday period.
Cooling:
EK Water Blocks Predator 140 All In One Watercooling Solution (incl.QDC) https://www.overclockers.co.uk/ek-w...watercooling-solution-incl.qdc-wc-9cm-ek.html
CPU Cooler, Water Cooler, Socket Compatibility: 775 / 1150 / 1155 / 1156 / 1151 / 1366 / 2011/ AM2 / AM2+ / AM3 / FM1 / FM2
Was £178.99 inc VAT.
Now £158.95 inc VAT.
ORDER NOW
EK Water Blocks Predator 360 All In One Watercooling Solution (incl.QDC) https://www.overclockers.co.uk/ek-w...watercooling-solution-incl.qdc-wc-874-ek.html
Was £203.99 inc VAT.
Now £182.99 inc VAT.
ORDER NOW
Sapphire Vapour-X w/ Dual Fan 120mm CPU Cooler https://www.overclockers.co.uk/sapphire-vapour-x-w-dual-fan-120mm-cpu-cooler-hs-001-sp.html
Socket Compatibility: 775 / 1150 / 1155 / 1156 / 1151/ 1366 / 2011 / AM2 / AM2+ / AM3 / FM1 / FM2
Was £42.95 inc VAT.
Now £25.99 inc VAT.
ORDER NOW
NZXT KRAKEN X61 280mm AIO Water Cooling Unit https://www.overclockers.co.uk/nzxt-kraken-x61-280mm-aio-water-cooling-unit-hs-014-nx.html
Was £118.99 inc VAT.
Now £104.99 inc VAT.
ORDER NOW
Three Fan Bundle - be quiet! Shadow Wings Fan Low-Speed - 120mm https://www.overclockers.co.uk/thre...adow-wings-fan-low-speed-120mm-bu-005-bq.html
High quality silent fans from Be Quiet are perfect for any system cooling configuration.
Was £32.99 inc VAT.
Now £14.99 inc VAT.
ORDER NOW
NZXT Kraken X41 AIO Cooler + HUE+ Bundle https://www.overclockers.co.uk/nzxt-kraken-x41-aio-cooler-hue-bundle-hs-018-nx.html
NZXT X41 AIO Cooler, 140mm Cooler, HUE+ RGB Dual Channel LED Controller - Black
Was £151.99 inc VAT.
Now £121.99 inc VAT.
ORDER NOW
Corsair Hydro Series H80i v2 Extreme Performance Liquid CPU Cooler (CW-9060024-WW) https://www.overclockers.co.uk/cors...iquid-cpu-cooler-cw-9060024-ww-hs-037-cs.html
Was 99.95 Inc. VAT
Now £74.99 inc VAT.
ORDER NOW
Corsair Hydro H105 240mm Extreme Performance Liquid CPU Cooler (CW-9060016-WW ) https://www.overclockers.co.uk/cors...iquid-cpu-cooler-cw-9060016-ww-hs-025-cs.html
Was 109.99 Inc. VAT
Now £84.99 inc VAT.
ORDER NOW
Storage:
WD My Cloud EX2 Ultra 2-Bay 3.5" Network Attached Storage https://www.overclockers.co.uk/wd-m...y-3.5-network-attached-storage-hd-53a-wd.html
A 1.3 GHz dual-core processor for high performance and ultra-fast transfer speeds. Simple system management for personalized backup.
Was £149.99 inc VAT.
Now £134.99 inc VAT.
ORDER NOW
WD 4TB 3.5" My Cloud EX2 Ultra Network Attached Storage https://www.overclockers.co.uk/wd-4tb-3.5-my-cloud-ex2-ultra-network-attached-storage-hd-523-wd.html
A 1.3 GHz dual-core processor for high performance and ultra-fast transfer speeds.4TB of centralized storage for your entire network. Simple system management for personalized backup.
Was 289.99 Inc. VAT
Now £259.99 inc VAT.
ORDER NOW
Seagate FireCuda SSHD 1TB 7200RPM SATA 6Gb/s 64MB Cache HDD - OEM (ST1000DX002) https://www.overclockers.co.uk/seag...64mb-cache-hdd-oem-st1000dx002-hd-36m-se.html
Part of the Compute Guardian Range, 1TB Capacity, 3.5 inch, SATA 6Gb/s Interface, 7200RPM Spin Speed, 64MB Cache, 5 Year Warranty
Was £76.99 inc VAT.
Now £65.99 inc VAT.
ORDER NOW
Lot's more deals have been added and more will be added on a daily basis. I will try and include them in this section as they happen. Lot's of SSD's and M.2 drives available but they are not products I look after.
All Black Friday Deals can be viewed HERE. Plenty of deals available already
Cooling:
ORDER NOW
ORDER NOW
Was £42.95 inc VAT.
Now £25.99 inc VAT.
ORDER NOW
ORDER NOW
Was £32.99 inc VAT.
Now £14.99 inc VAT.
ORDER NOW
ORDER NOW
Was 99.95 Inc. VAT
Now £74.99 inc VAT.
ORDER NOW
Was 109.99 Inc. VAT
Now £84.99 inc VAT.
ORDER NOW
Storage:
ORDER NOW
Was 289.99 Inc. VAT
ORDER NOW
Was £76.99 inc VAT.
Now £65.99 inc VAT.
ORDER NOW
