Robocopy switches
20 Oct 2002
London
I was just wondering if anyone could check this robocopy script I have. It's basically to copy office files.
robocopy "F:\Office" "Z:\Office Backup" *.* /S /IS
I just wanted to check the switches I'm using. I'd like it to do the following:
- Ensure modified files are updated/copied again
- Log results of files moved successfully (I couldn't figure this out?)
- Not delete files on the backup drive that have been deleted from the original
Is what I've got essentially right (minus the log?)
Thanks.
robocopy "F:\123" "F:\12345" /e
that's what I use.
What do you mean by log results mate, do you want a txt file log output?
/LOG+:c:\log.txt
Thanks guys. I've done more work on my script(s) and have got the following working really well, complete with nice logs.
Code:
robocopy "F:\source" "P:\destination" *.*  /XD dirs $RECYCLE.BIN "System Volume Information" /IS /E /V /TEE /XA:SHT /NP /LOG:"G:\BACKUP LOGS\My Log.txt"
However even though I have the following switches:
/XA:SHT
On one of the copies I keep getting the specified^ directories copied, which are hidden/system folders. And also one of my backups keeps changing itself to a hidden/system folder which I can only see when I change my viewing options to not "hide protected operating system files". This is annoying when I want to just quickly look that the files have copied.
Any ideas? Can I change the copied files from system files? :)
just type /XD "$RECYCLE.BIN"
leave out the 'dirs' bit
I think MS say it's a good idea not to robocopy a root dir (may be able to get around it using excludes though)
