Robot bricklayers that can work round the clock coming to Britain
Industry looks to mechanisation as chronic labour shortage hampers construction
That would make "none standard construction" and your going it hard to get a mortgage on one.I can't see this ever taking off tbh. Far easier and cheaper to just build prefab stuff.
That's the sort of thing that always makes me sceptical, it's like the 3d printed houses which IIRC still require at least as much secondary work (often more) to finish off what would normally be done by the brick layers.
Personally if we're looking to speed up standard house construction, something like modular building sections would probably be more realistic at the moment, completed wall sections could potentially be carried on the back of a slightly modified trailer, with the only onsite work being bolting them together and laying foundations (most of the complicated work could be done in a factory setting where things like weather would not affect it at all).
IIRC they've been working on them/playing with them for quite a while, the problem is that they are relatively limited in what they can do and whilst they can in theory "work around the clock", they won't, because that would require a lot of humans also working around the clock to supply them/monitor them/fix them and to do the bits the robots can't do but have to be done before the next stage.
I'm guessing if you were building cookie cutter houses they could potentially work in an offset timing so a few of the robots running and a smallish number of humans who are tending them, and as robot 1 reaches a point where it has to pause for human intervention robot 2+ can keep going, then robot 2 needs the attention whilst 1 and 3 on are running.
I suspect even if these take off, there will still be a big shortage of the electricians, plumbers and gas fitters, jobs that are much more complex than the basic "lay some cement, place 10 bricks, space, lay 5 bricks" stuff that can be done by virtually anyone (and is often the stuff left to the apprentices/lower skilled brickies).
From what I've seen, they don't put those in new builds anyway, they just put fake ones in after.weep holes
How about robots building homes out of asylum seekers? Modern problems require modern solutions.Robots building homes for asylum seekers,..what is this country coming to.
Aye IIRC the originals included things like compressed/recycled cardboard with a glue binder (similar to hardboard), oddly enough they stopped that and I think destroyed all the ones that had been built after a major fire.They made a ton of houses like that after the second world war, and although a lot of them were only designed to be lived in for 10 years, some are still lived in today.
Most of them were pretty substandard though, a lot of the ones today were subsequently repaired by local councils over the years.
I'm not saying good quality pre fab housing isn't achievable by the way, just saying it's nothing new, and also not something that ever really took off.
That was my thought pretty much, one of my neighbours about 30 years ago built an extension in his free time, IIRC no professional help apart from the plans and roof. He had no experience before, so I think took a short course (anyone remember the old night courses you could do at local collages?), and then got onto it.Yep, labour shortage affects complicated roles more. Anyone can lay a brick
We've got a lot of them in my home town, still standing and lived in today although like you said they have needed in most cases a fair bit of work to keep them that way.They made a ton of houses like that after the second world war, and although a lot of them were only designed to be lived in for 10 years, some are still lived in today.
