I have a McCuloch, made by Husqvarna, single guide wire rated upto 800m2. Boundary wire is about 450m.
So quite a large area. We only got it going this season but ive learned a lot from trial and error.
2 guide wire models are very expensive.... Ideally i needed a 2 guidewire jobby but we compromised and went with the cheaper.
it still works, but its set to cut nearly all the time, it finds its way everywhere, but it would have been better with 2 wires.
if you put your base station in 1 of the more remote parts of the garden then you can forget about running a guide wire
80 looks good then a long guide to 150 is possible.
They say that they can negotiate small corridors but id try and give at least 1m in width at the smallest path when following a guide out/in cable. They use a randomized distance to the right of the cable out, left in, as not to leave tracks and wear and tear on the surface.
Mine has to negotiate a small area/corridor to get out into the main garden lawn and it took a lot of trial and error to get it through smoothly. So My advice go close to a boundary wire in a corridor with the guide cable, mines less than 20cm, but that is fine for my model.
I'm not sure how its going to do with a gravel path though... and you have to boundary and guide cable there too....
Mine has a ACS system......
btw thats not a video
