- 1 Jan 2009
- Northampton
OK so I have a Roccat ISKU FX Keyboard and I want to change the default audio voice as it sound creepy.
I located the directory where all the wave files are stored
C:\Program Files (x86)\ROCCAT\Isku FX Keyboard\Wave\Volume
and started replacing them with my own wav sounds.
However when I go to use the keyboard profile switch which would initiate a sound response.. all I get is silence.
I made sure the wav files are the correct name and format but it refuses to play any audio that has been replaced.
Any advice? Thanks
Any advice? Thanks
