** ROCCAT KAVE SURROUND SOUND HEADSET - WEEK LONG SPECIAL **
rjk
rjk
Caporegime
8 Aug 2007
Hi Guys
Starting from today and finishing in a weeks time, we are offering the simply superb Roccat Kave surround sound headset for a brilliant price.
This is the lowest price in the UK from any major retailer and this deal can be used in conjunction with free shipping for qualifying forum members.
This is a brilliant headset and easily one of our best selling lines in the OcUK headset range.
Pick yours up now!
Roccat Kave 5.1 Surround Sound Analog Gaming Headset @ £59.99 inc VAT
A Desert Eagle isn't worth its fancy name, if you don't know where to aim. Imagine your advantage within the heat of the battle when you exactly hear where your opponents are before you can actually see them. Knowing the position of your enemy is half the frag. Realistic 3D surround sound makes you locate your opponents easily by the noise they generate. The desktop control enables you to adjust to situations quickly with sound and microphone mute buttons and volume control for different channels.
- Real 5.1 Surround sound with speakers aligned at a 12° angle
- Microphone with mute LED fully rotatable and completely removable
- Tip’N’Control desktop remote for central management of all volume functions
- Dual sound-profile with movie and game settings
- Solid aluminium hinges enabling heavy duty use
- Hand-sewn comfortable earcups featuring external noise cancelling
- Adjustable vibration unit for a realistic gaming experience
- Headband with three pads for equal weight distribution
- Easy to carry folding and compact design
Was £65.99 Inc. VAT
Only £59.99 inc VAT.
ORDER NOW
A worth buying headset for that price tbh. They are my gaming headset of choice because the proper 5.1 really helps you in games when you really need precision such as FPS games - they are also a great set for music, currently my work pair of headphones also
Our Kave supplies are moving fast this week. Be sure to pick yours up at this great price point before it goes back up on Monday!
