Roccat Kone+ and macros (issue with macro execution times)
Hello
Has anyone else noticed problem with Roccat Kone+ mouse and macros - issue is related to MMORPG games where u need get certain key combinations repeatedly.
I'm playing WoW:Cataclysm - as warrior and shaman on one case i would like to have keyspam 2 till 7 and second button 8..0
While using Kone+ with their latest firmware and driver (of course resetted ) mouse and driver settings after install and applaying update.
I keep receive erradic response from mouse - macro runs thru 1 step normally, second time _maybe_ normally) then stops up to 4 seconds i press key - nothing happens , then macro goes again, response time mose-knob4 press <macro> <mousekey press> - between keypresses appear timeframes 1900ms to 3600 ms.
While i spam same sequence on Microsoft or Razor mouse max delay i encountered was 190 ms - may be my own thumb getting tired.
I used mouse record Pro 1.3 freeware software (http://www.softpedia.com/get/Others/Miscellaneous/Mouse-Recorder-Pro.shtml) to record 3 mices at once, everyone of them connected and appropriate drivers installed (intellimouse 8.0, Razor 6.10 and fw 6.32, kone+ Driver 1.33 and fw 1.24)
other 2 - Microsoft optical Wireless mouse 3000 and Razor Copperhead
appear sending signals in 20 ms while Kone+ appears sending sequence 30 to 60 ms between commands i entered in macro and after macro ends stops for amount of time which varies.
Same was for timed macro i created for shaman - key 2 <instant spell> key 3 <1250 ms wait> key 4 <1660ms> key5 <instant> and so repeatedly.
This one did not worked.
Second macro was just ordinary Lightning bolt spam - which worked (key <wait 1660ms>key<wait 1660ms>.
Was buying the mouse specially to get "timed macros".
Can anyone confirm this issue ?
Hello
